Various xj mj wj parts
altrocker1
Iowa
LOCATED IN JAMESTOWN NY
I have an ad going on craigslist, but i keeps getting flagged...i will try to keep tis updated and will ship small parts. if things don't sell soon, a lot of this will be going in the trash or to the scrap yard...
here is the list since some jerk keeps flagging it...
Lot one small or cheap xj/mj/tj parts:
-xj mechanical clutch fans (i have 2) $5 each
-97+ Fan Shroud...missing top screw tab $5
-Stock xj downpipe...needs hanger welded back on, comes with 02 sensor that is newish $5
-Climate controls from a 99 xj...$10
-turn singnal and side marker lenses...new and old style $5
-manual belt tensioner from a 99 (will fit a lot of years) $5
-Stock ubolt plate set...very solid $5
-Throttle cable, cruise cable, kickdown cable bracket for 99+ manifold...$2
-stock xj shackle $5
-4.0 crank from a 2000 xj...will need machining. $10
-peugeot ba 10/5 manual transmission with bellhousing for 4.0. $20
-NP 231 21 spline input $25
-xj/mj tan hood in okay shape $10
-2000 xj cylinder head...needs a good cleaning. $20
-xj auto trans cross member $10
-xj manual trans cross member $15
-xj electric fan from a 2000...was only used for 3 months after purchase. Stock connector was cut off but you can splice yours back on it. $30
-99 PDC and harness...may have a few connectors cut. $5
-xj top radiator support $5
-advance auto xj radiator for open systems...used 5 months. $30
-2000 xj AC condenser...$5
-xj tan center console lid working latch $5
-upper radiator hose (i think) $5..was used 5 months
-xj water pump pulley $2
-xj stock tow hooks with brackets $20 SOLD
-2000 xj electric blend door actuator $10
-87-96 rear wiper motor $5
-97+ center console support $20
-2000 xj piston rods (have 4 good ones) $10 each
-rebuildable 2000 xj engine block $20
-4.0 oil pan (not rusty) $10 SOLD
-tan under steering wheel cover $5
-broken fog light $1
-1998 headlight switch $5
-alternator front and rear bracket set $5
-lot of misc working sensors $10...2 cps, 2 tps, one cam sensor, several other sensors included
-99+ intake manifold. $50
-97+ front clip wiring harness...some bulbs included (2 available). $10
-stock xj airbox $10
-fan clutch/idler pulley brackets $15 each
-engine side motor mount brackets $10
-aftermarket dorman exhaust manifold (few months old) $40
-1999 gas tank and fuel pump $20
-drivers side front gauge trim bezel $5
-older style front bumper $20
-stock front driveshaft new ujoints...may need centering ball $35
-durango upgrade steering box $50...was brand new. Has 200 miles on it
-HD steering box spacer...home made $20
-99 ac compressor working, but had a frozen bolt in it...should be able to hammer out and make it work $20
-washer bottle for 97+ $5
-power steering pump...broken outlet..good pulley $5
-valve cover $15 SOLD
-stock 99 airbag $25
-passenger side front brake pad set...$5
-96+ throttle bodies $10 each
-extended front bump stops $5
-turn signal switch $5
-wiper switch $5
-good set of gas tank straps $5
- 99 injector/engine sensor harness...i believe its un cut $20
-poly RE conical bushings...larger size $5
-RE extended rear brake line $25
-1999 airbag computer $10
-1999 coolant overflow tank $5
-black radio bezel $5
-lot of fender flares $10
-door step trim panels $5
-Stock sway bar $5
-behind gauge bezel support for 97+ $5
NEW or MORE EXPENSIVE PARTS:
-new ubolt sets...full set for dana 44/35 xj rear with nuts $25
-New ubolt pair 2.5" ID...$5
-New Ubolt pair for dana 44/35 with no nuts $5
-single rear monroe shock for stock xj $20
-leaf centering pins $5
-zone bar pin eliminator set $20 with hardware
-misc ujoints $5
-front grille, fenders bezels, lights wiring for 97+ xj...primed. $175
-7" anti wrap perches $30
-stock leaf perches $20
-weld on shock mounts $20
WJ PARTS
-Main fuse box -$10
-sliding seat tracks $5
-power seat base $25
-dash $10
-CHrome front grille $20
pics of parts:
http://s528.photobucket.com/user/altrocker2/library/
which front driveshaft is it (length or part #)?
I may take the BPEs - have the sleeves?
going to NacFest?
Nice sheep... :)
going to NacFest?
Nice sheep... :)
im from the mwc originally...sheep are family
i have the sleeves and bolts for the bpes yep...the driveshaft is from a 99 4.0/242 combo so it would be whatever the stock length is. it has 3 brand new ujoints in it, though the caps fell off the back joint because i'm an idiot and didnt put tape on them. i won't be at nacfest :( i really want to head out there sometime though. i can ship things pretty cheaply through work though so it wouldn't be a lot to load them up and ship them. it would be less than $20 to ship...probably around $15
lot one small or cheap xj/mj/tj parts:
-xj mechanical clutch fans 1 left $5 each (ONE SOLD)
-aftermarket dorman exhaust manifold (few months old) $40 SOLD
-durango upgrade steering box $50... Has 200 miles on it SOLD
-wiper switch $5
-Stock sway bar $5
-misc ujoints $5
WJ PARTS
-Main fuse box -$10
-dash $10
