Yes, you have to have something there. You can reinforce the existing cross member, build a stronger replacement, or tie the two frame rail ears together with some sort of bracket. The factory tow hooks use a reinforcement bracket.
I don't have pics right now (found pic, bottom), but to mount my winch I used the frame re-inforcements I made (same as CRok and others) than put a piece of 6" wide 1/4" thick plate going from one frame plate to the other. The winch ount is also bolted to the bottom of the crossmember using some 2x2 angle.
I didn't cut out the crossmember at the time cause I was in a hurry to mount the winch for a weekend run, but I expect to cut much of the crossmember out in the future when I do some work on it this winter. I will hollow the center out to allow better airflow for the winch and rad (Taurus fan sucks air from down low too). I want to keep it (x-member) there for when I remove the frame plates, so the front end will have some structure to it (on the off chance I need to)
