mrbill3
- Central Coast, CA.
Yesterday I started getting bump steer. I searched, but I didn't find any mention of one of the symptoms I have. About a week ago I noticed a clunking noise in the front end. I had my daughter yank the steering wheel from side-to-side and I noticed that is there play in the ball-stud on the upper end of the track bar. (I ordered a new Rusty's adjustable one and also the upper mount on Tues.) About 2 days after I started to hear the noise, the steering wheel started to go off center clockwise about 3/4 inch.(It's not pulling to either side) Then yesterday the bump steer started. I went over a bump in the freeway and no problems. About 2 hrs. later I went over the same bump again and that's when it started. Now seems to be happening on every bump, not on potholes, and the steering feels a bit sluggish. As for my rig, it's an 89 Laredo, 4.0 automatic with 3" full spring pack lift with new shocks, new steering stabilizer, bump stops and steering box brace, all from Rusty's. It also has new ProComp 31X10.5X15's on new 8" black steelies that were balanced and installed about 2 months ago. I installed all the gear myself (had the tires balanced and the alignment done at a local 4X4 shop). My question is would the bad track bar cause the steering wheel to go off center and the steering to feel sluggish? I know it can cause the bump steer and I hope the new one stops it.
