CRASH
- Foresthill, CA
LouisianaZJ said:
Is it me, or did that thread actually have more positive experiences with synthetic than negative?
CRASH
LouisianaZJ said:
OneTonXJ said:I want photographic and possibly movie proof that this thing runs under its own power. :wave:
Goatman said:Anyone want to post up the part number on the replacement filter on the AW4?
I've had mine serviced numerous times.....never replaced the "filter". We did clean off the screen, however.
I was thinking of putting Redline ATF in my AW4... but I Think thats synthetic..LouisianaZJ said:do NOT run synthetic as suggested above :sunshine:
Actually the AW4 is not a Toyota tranny, it is manufactured by Aisin Warner and used by Jeep, Toyota, Isuzu, Mitsubishi, Nissan, BMW, Volvo... and possibly more. There are 3 Jeep versions (Renix, HO, and 2.5 engines) at least 3 Toyota versions, and likely many others between the other companies using them.BLSXJ said:today I had a long conversation with a guy at a tranny shop here in windsor that does alot of the "big 3" R+D/ audits of they're tranny's.
I went in looking for a shift kit and he confirmed that the tranny is actually a toyota tranny and the thing is tough as nails. and does not need a shift kit to hold up to the power of any jeep I6 (including strokers) w/ up to 35" tires
he did reccomend a cooler placed in line between the tranny (output) and the stock cooler in the rad. the logic being the hot fluid is cooled in the cooler then warmed backup to operating temp by the in rad cooler, thus keeping the fluid right in the proper temp range.
he also said with 4 wheeling and all it would be a good Idea to change the fluid every year and as long as the fluid stays clean there would be no real need to go up to synthetic.
he also said that if you ever do destroy a tranny there are so many XJ's out there that just getting another would be the way to go.
woody said:Both mine use a spin-on NAPA Gold (Wix) 1068 :laugh3: Motorcraft FL1A and AC PF2 work in a pinch.
I added a spin-on filter to the cooler circuit.
