- Brighton, CO
Waggy Dana 44, driver drop 5x5.5 pattern
5.38 Spicer gears, Detroit locker
Alloy USA shafts with Longfield 300 U-joints
Warn premium lockouts
Poison Spyder high steer arms with 5/8" studs (far hole drilled to 3/4", near hole is 1 ton taper)
Spares include: 1 set of stock shafts (inners and outers with stock u-joints), 1 set of Yukon outers, 1 pair of new Spicer U-joints, 1 pair of used Warn lockouts, 1 set of stock Waggy slugs.
Trussed and set up for triangulated 4 link with heims
$900
Shaved 35 spline rear Dana 60.
WMS ~62". 5x 5.5" bolt pattern
Detroit locker
5.38 Yukon gears. Ring gear turned down .500" in diameter
Moser shafts
Ruffstuff cover
Disk brakes
It has ORI strut mounts on top of the axle (not pictured) and Coilover mounts on the rear of the axle. I'm currently running the ORI's and haven't cut the old mounts off yet.
Build thread here:
http://www.naxja.org/forum/showthread.php?t=960530
$1100
(5) 38x12.5x15 TSL SX on 15x8 Allied Rock-a-Thon Beadlocks
5x5.5" I think the back spacing is 3.75"
2 @ 15/32
1 @ 13/32
2 @ 10/32
All hold air, No patches or plugs. Normal trail wear and cuts. The spare has a bent beadlock ring, but holds air as well. I'd prefer to sell as a set, but will separate if I have buyers for both.
$1000
I'll make a better deal if you want everything.
-Jon
$900
Detroit locker
Moser shafts
Ruffstuff cover
Disk brakes
Build thread here:
$1100
2 @ 15/32
1 @ 13/32
2 @ 10/32
$1000
-Jon
