built 93XJ part out
You still have 2 of those 5150's? You have the adaptors to run them in the front of an XJ too? How many miles are on them roughly?
And I got the belly skid but did you forget to give Wade all of the hardware or do you just not have it, he only said he got 1 bolt and 1 bracket?
ian, i sent you a message on fbook.
current state:
tires:
tread on the 10.5s; the 12.5 is only good for a spare, its worn uneven and dry rotted.
coils/re arms:
itty bitty hayden cooler... glove for size
rk trackbar:
guages/overlay
idk why some pics are smaller than others, my phone has been being retarded ever since it became a hood/intercooler sandwich.
NP242 (original, 182k) w/ hack & weld SYE.. just like a hack and tap, but the yoke was welded on instead of bolted. it works, leaks a teensy bit (like a drip, never had to replace fluid over the 8200 mile trip) but you wont be able to change the seal well, bc its welded.
make an offer
(4) 33x10.5 BFG MT KM1s on 15x7 Jeep Eccos w/ custom rock rash- $200
-two front tires are 25%
-one rear is 50%, the other 65%
(1)15x7 Ecco $20 comes with free 33x12.5 BFG radial MT spare
AJ's 3/16" SuperRails, rashed, dented - $175
4.0:
(original) 182k
Compression is meh, havent checked in two years, I know the oil control rings are bad in at least 2 cylinders
no power steering pump
no header
comes with stock intake manifold, not bolted on
no throttle body
wound up (100A i think?) rebuilt alternator with ~20k on it
leaks here and there (duh)
still pulls strong as hell though
make an offer
AW4:
(original) 182k
shifts firm, doesnt burn fluid
custom high clearance, low capacity pan
make an offer
Rock Krawler HD Trackbar & Bracket (uses big ole 9/16" bolts) 8k miles on it $185
RE 3.5" Coils - $100 (pending)
RE SF Fixed LCAs, bushings are a tad loose however they're not even a year old - $120
hella 550s (the bigger rectangle ones, no wires) - $30
durango steering box, 8200 miles on it- $150
gauge cluster with glow gauges and overlay - $20
APN header $80
99+ intake manifold $80
63mm thefastman bored throttle body $50
all interior parts available except the drive front seat and drive door guts
i needs the exhoost mannyfold before unibody run
i think more fumes exit my header than my tailpipe
so i either need to to to the island or you come to the mainland or you put some cardboard on it or something.
I have one you can borrow till you get that one if it really comes down to it... would just give it to you but I've got a couple cracked manifolds and need to replace them eventually!
ya know. i just remembered i still have my 96
and it has a manifold. but looks repairable. i might just rob that and see what i can do it with
hope it doesn't have a bullet lodged in it :roflmao:
do you have a welder? I forget. If you don't and it's only got some small cracks, roll on up and I'll throw the extension cord over the fence and blow some boogers on it. I'm planning on putting a flex joint into one of the collector tubes on the one I have so that it won't crack... or won't crack more, not sure which.
the one on my 97 blew out one of those flex tubes.
i can weld it up anyway thanks though
BTT this thing needs to get out of my driveway. its gonna get scrapped as-is with the motor/tranny/everything unless people want stuff. i'll be at the unibody run and can bring whatever on one of my friend's rigs.
You should harass someone into rebuilding that 4.0 as a stroker :thumbup:
Still got the tranny pan for whoever picks up this guy's transmission.
