D30-
good:
gusseted LCA mounts & pass side UCA mount
4.56 Yukons
NAPA premium 260x u joints
Spare 297x shafts (one long and one short)
trackbar mount drilled out to 9/16"
one ton steering
solid diff cover
rotors, calipers, and pads have less than 10k on em
lubelocker
always run w/ full syn fluid
bad:
both hubs are making noise
pass side ball joints are shot
its a teensy weensy bit bent at the Cs
the good part is, hey, you'll be replacing the ball joints so you can get adjustable ones yay!
$500
(someone is a maybe on this, waiting on a confirmation and more importantly, cash money.) it's still under the truck, no pics as of now. i work until the afternoon then it rains once i'm out of work til it gets dark, so i havent had time to pull much of anything else yet.
NP242 (original, 182k) w/ hack & weld SYE.. just like a hack and tap, but the yoke was welded on instead of bolted. it works, leaks a teensy bit (like a drip, never had to replace fluid over the 8200 mile trip) but you wont be able to change the seal well, bc its welded.
$85
solofabworks front bumper w/ d-rings $200 (ties in all the way back, has 2 hella 500 mounts welded on)
(4) 33x10.5 BFG MT KM1s on 15x7 Jeep Eccos w/ custom rock rash- $200
-two front tires are 25%
-one rear is 50%, the other 65%
(1)15x7 Ecco $20 comes with free 33x12.5 BFG radial MT spare
AJ's 3/16" SuperRails, rashed, dented - $175
4.0:
(original) 182k
Compression is meh, havent checked in two years, I know the oil control rings are bad in at least 2 cylinders
no power steering pump
no header
no intake manifold
no throttle body
wound up (100A i think?) rebuilt alternator with ~20k on it
leaks here and there (duh)
still pulls strong as hell though
make an offer
AW4:
(original) 182k
shifts firm, doesnt burn fluid
custom high clearance, low capacity pan
make an offer
(2)Bilstein 8" 5150s.. some rash on em, but they all extend/compress like new- 255/70 valving $125
Rock Krawler HD Trackbar & Bracket (uses big ole 9/16" bolts) 8k miles on it $185
RE 3.5" Coils - $100
RE SF Fixed LCAs, bushings are a tad loose however they're not even a year old - $150
Rock Krawler UCAs, 2yrs old, like new bc RK is beefcake - $150
hella 550s (the bigger rectangle ones, no wires) - $50
durango steering box $150
factory steel gas tank skid $25
