Built 29 spline C8.25
Status
Not open for further replies.
XJensen
Sacramento
I am selling my built 8.25 to swap in a Dana 44. This axle has been great to me and has been well maintained.
It does have a very slight leak, a drop every day or two, from the pinion seal. This is from some rock rash during the Reno trip I took recently. The axle is still under my jeep but it just sits in my garage and can be pulled in about two hours.
specs
C8.25
4.56 gears professionally installed
auburn limited slip
Ruffstuff diff cover counter sunk holes
lube locker
hardened shafts and stock spares
ZJ disc brake conversion
shock mounts in the stock location
new never used grade 8 u-bolts
$700 with discs obo
$600 with drums obo
If i decide to part it out it would be
$80 hardened shafts
$60 for the Ruffstuff cover
$140 for the disc breaks
$20 u-bolts
$500 for the axle with stock cover and drum breaks
Josh
Interested in the shafts. I'll be in sac this tuesday
specs
C8.25
auburn limited slip
lube locker
$700 with discs obo
$600 with drums obo
$80 hardened shafts -- SOLD
$60 for the Ruffstuff cover -- SOLD
$140 for the disc breaks -- SOLD
$20 u-bolts
Josh
Still have the grade 8 u-bolts and axle with drum brakes, stock shafts and stock cover.
Thanks for the shafts Josh. Sorry about the confusion with the cover.
I'm looking for a locker/LSD..I've got a C8.25 out of a 2000 I believe which is 29 spline..
Any info on that LSD?
If its out of a 2000 then you have a 29 spline. Mine has 4.56 gears and an auburn limited slip, aftermarket unit.
I am not parting out the unit but am selling the entire axle pretty cheap.
Josh
Hmm...4.56 gears and 31" tires on a DD that sees 99% pavement. 4.11's I'd be all over this but I have to think about the 4.56's.
Status
