Built 1995 Jeep Cherokee XJ in Arizona
redneck
I just haven't had time to use it and its sitting. It was built up in the summer of 2010 and I have only taken it out wheeling once. It was rebuilt with good quality parts and has around 3000 miles on everything since then. It started life as a 1995 Jeep Cherokee Country Edition w/ I6, AW4, NP231, D30/8.25. The odometer reads around 173K miles but that's just the body. This Cherokee was literally pulled apart to the shell then rebuilt with all new parts. I have receipts for most things on it and pictures of the build. 4.6L stroker with all new internals and sensors, new out of the crate AW4, new Atlas II, Currie front D44 and rebuilt XJ rear D44 axle, new drive shafts. The only things not replaced on the body is the wiring and body itself. The unibody has been plated from nose to tail the sprayed with Raptor liner bed liner.
BUILD LIST
Axles
Front Dana HP44
-Currie HP housing and tubes
-4.56 G2 gears
-WJ knuckles
-Gusseted knuckles
-RCV shafts
-ARB locker
-ARB diff cover
Rear XJ Dana 44
-4.56 G2 gears
-Tube truss
-Superior Jeep Super 44 Rear Chromalloy Axle Kits, 33 Spline
-33 spline ARB locker
-Solid diff cover
-Teraflex disk conversion
Steering
-PSC hydraulic assist
-1.25x.25 DOM tube with heims
-MORE steering box brace
-JCR steering box spacer
Driveline
-New AW4
-Atlas II 4.3 transfer case
-315/75-16 BFG KM2's
-TJ Rubicon MOAB rims
Suspension
Front
-Rusty's radius arms
-Rusty's 4.5" coils
-JKS ACOS Pro
-Rancho RS9000 shocks
-T&J Performance upper shock mount conversion brackets
-Modified Rubicon Express track bar bracket
-Rubicon Express track bar bracket brace
-1.25x.25 DOM tube Track bar with heims
-Currie Antirock sway bar
Rear
-Clayton Off Road 4.5" leafs
-H.D. Off-Road Engineering Shackle relocation brackets
-Synergy Suspension Rear Spring forward Hanger Bracket
-Rubicon Express Boomerang Shackles
-Rubicon Express monotube shocks
-Upper shock hoop (mounted under floor)
Body
-H.D Off-Road Engineering full set of unibody stiffeners (from front to back)
-Raptor lined under body
-JCR Off Road winch bumper
-JCR Off Road stage 2 sliders
-Custom cut and fold rear bumper
-Full Exocage (powder coated)
-Swing away tire carrier built onto cage (2 different tire carriers come with it)
-All armor powder coated
-Rusty's gas tank skid
-Rusty's transfer case skid
-Rusty's engine skid
-Interior cage
-4 point harnesses front and rear
-2001 limited leather interior
-Overhead console with trans temp, air tank pressure, and all switches
-VIAIR Ultra Duty Onboard Air System
-Warn 9.5xp with Warn wireless winch controller (winch installed but not hooked up, never used, always covered)
-ORO LITESPOTZ rock light kit
-IPF headlights w/ H4 Bulbs
-ARB headlight harness
Engine
-4.6L Stroker (all new everything, accessories, sensors, etc...)
-Harland Sharp Roller Rockers
-Port and polished head
-Comp cam
-Double roller timing chain
-258 crank and rods
-Speed Pro Pistons .040 over
-LS1/LS6 Stainless swirl cut valves
-Chromoly Comp push rods
-Blue printed and balanced
-Volant 27740 Cool Air Intake
-Port matched 99+ intake (curved runners)
-Bored throttle body
-Ceramic coated Banks header
-Ford fuel injectors
-Brown Dog Engine mounts and engine plates
-CSF 3 core radiator
-Flowmaster 50
I have way more invested into it than I'm asking (doesn't everyone?). Asking $14,500 OBO. I will only be willing to part it out if I have a buyer for the body and exo cage. I don't have the room to have things that big sitting around. No unibody damage, no cracks, no body damage, and never abused. Clean AZ title in hand.
Heres the Craigslist ad with more pictures. Any questions, let me know! Texting is the best option to get ahold of me!
https://phoenix.craigslist.org/nph/cto/d/built-1995-jeep-cherokee-xj/6306563397.html
Thanks!
Aaron
602-seven9 nine -ten 87
