- Westminster, SoCal
OK, from the looks of it, at the build time I will have my UpCountry with the short AAL which has the mains tweaked, and 2 regular packs. The up country and regular seem to be similar with the exception of the lower most leaf which is slightly beefier in the upcountry.
Plan A: the plan is to take a good set of mains for new main (from regular pack), then take another main (either the regular pack or UpCountry... will compare both to each other) and shorten it at the eye to retain a bit of curvature as the next main leaf, then take the next big leaf that is regularly on the pack (either upcountry or normal, will have to compare them) and then the next leaf either upcountry or normal, will have to compare them)and then the UpCountry last one. This would end up being a 5 leaf pack with a BIIIG AAL and a bigger lowest leaf
Plan B: Similar to plan A except that for the second to last leaf, I would cut down the bigger leaf down to halfway in between it's original size and the one it's going to replace and I will still use the lowest leaf from the UpCountry
My objective is to get in the neighbourhod of 4" at this moment as I don't want to redo the front too much (maybe a small spacer on the coil springs). The bigger lifting will happen by next summer when I'm going to have the D44 ready with bigger tires.
Also when I'm assembling the pack what about spotwelding the ubolts to the lower leafs for keeping the pack from separating? I have seen some leafs that had those prebolted (welded?)somehow. This would help the droop (I hope).
Thanks
Kejtar
Thanks
Kejtar
