JEONLYEP
- N 37° 48.485 W 100° 20.903
I saw a couple of plans for sheet metal brakes online, so I decided that I should build one for myself. (36" max width)
(Plan 1)(Plan 2) I made my plans mainly from plan 1.
Material list: (Stand material not in list)
* 7' of 4" C channel (2 @ 41")
* 4' of 2" x 1/4" Angle (1 @ 37", 2 @ 2 1/4")
* 3' of 3/8" x 1 1/2" Flat (4 @ 5", 2 @ 2 1/2")
* 3' of 3/4" Rod (2 @ 18")
* 1' of 3/4" Sch 40 pipe (2 @ 5")
* 4' of 3/8" Rod (1 @ 38" bent in the middle, 1 @ 4")
Pile of metal to be used.
Part of the top clamp #1.
http://i60.photobucket.com/albums/h8/Jeonlyep/My%20brake/IMG_2444.jpg
Top clamp #2.
Top clamp #3.
Pieces of the bottom.
Basic idea for one side, and the parts for the other. C channel is upside down, in other words, you're looking at the bottom of the brake.
Basic idea, second view.
Drilling the hole for a bending lever holder.
Bending lever holder in as it will be used.
Hinges laid out.
Drilling the holes for the hinge pins.
Most all parts cut, bent and drilled.
Top clamp #2.
Top clamp #3.
Hinges laid out.
