Hmm, looks,like my name is no longer red. I guess I better fix that.
Been busy this last week, fixing a couple things on the Jeep that I've been putting off for awhile.
For some time now, my steering had developed a wobble or Oscillation during moderate to tight turns. Super Annoying. I read a bunch of what it could be and almost everyone said it was the front Axle U-joints. Sure enough, Both U-joints were seized solid. I've never seen a u-joint fail in such a way, but nevertheless its fixed now and good to go.
The next thing on the list of crap to do to the jeep was shackle relocators from HD offroad.
My shackle angle was, well, nonexistent to say the least. The back end was very bumpy and would jar your insides out going over bumps in the road. I ordered the Bolt in version of the relocators, I didn't really want to gain any height, but, I really didn't want to cut the stock box out, Since the only cutting tool I have is a Angle grinder.
Im glad I used anti-seize on my leaf spring bolts, they came right out which saved me boat loads of time and anger.
As you can see, my shackle was bottoming out on the stock box, and had bent it slightly.
Installed the Anti Crush sleeve, and the mounting bracket in the stock box. I installed it over my skid and hitch, just for ease of installation. If I ever have to pull the tank skid or hitch, I'll reinstall them under the hitch.
(sorry for the large pictures, photo bucket is not letting me resize my pictures for some reason.)
If you noticed, I only have two bolts on the bracket, the third (middle) hole is nonexistent.
Ready to Install the shackles and tune my angle.
Took a Little bit to figure out where I wanted my jeep to sit, as well as my shackle angle. But I finally got it figured out. I gained about 3/4-1" which wasn't bad since my rear was slightly lower, now its slightly higher, But I think it looks good. Not to mention the ride is much better and the handling is much more predictable.
Here's a before and after.
(obviously the before was taken awhile ago....)
Getting ready for our Road trip back to Utah. By the end of this month, my jeep will once again be in the Intermountain Chapter.
Defiantly Planning on hitting up some trails while we're out there.
