- Henderson, NV
You degree a cam because most manufacturer's don't use straight up timing. In the case of your Comp cam, it is suggested to run 3* advanced!
Interesting, how do you degree it with out buying a new cam sprocket? I never went through checking the degree of the cam. The install instructions that came with the cam said it wasn't necessary and referred to the FSM for installation of the cam.
I'll have to do some more research on this and see what I can find. I know the cam I bought is -4*retarded, so if I was supposed to be installed 3* advanced why have the -4* in the first place? Just thinking out loud.
