Depends on the SYE you are going to be using. If its just a hack-and-tap, then you can do that without removing the transfercase, and there's no need to open (high mileage refresh is a good reason but not A does not require B). If you are getting a shaft replacement then you will have to open it anyway ofc, and its easier on the bench where you can keep track of everything, and then yeah go ahead and replace stuff because its there and open already. The biggest thing you'd want is a new chain since 220k miles the original is probably stretched (you can replace this with the case still in the jeep, btw). You are probably missing the pads for the shift forks, little plastic things that get torn up. At that point you are pretty close to the front bearings anyway. rockauto.com has Cloyes chains, and SKF and Timken transfer case overhaul kits. There are other sources depending on budget and parts included, G2 uses Timken bearings for their less expensive kits. I would not buy anything that did not clearly identify the bearing manufacturer.So I'm gonna go 8.8. I'm lifting the rig 5.5 so I need an sye obviously. While I'm in that case should I rebuild it. Should I replace the chain? 220k on the clock. Where should I get the parts? Are there differences between the eBay cheapie and the expensive stuff from jb. Also since I gotta pull the t case will it be a problem with my iron rock lift to install it without the t case in place? Can I get the t case back in with the IRO LA bracket installed?
Eh I have to pull the engine and Trans for my om617 swap ...
I didn't know they had a torch man. I may never take a tool to pick and pull again...![]()
I imagine the torch works great! Not sure how the parts would work after though...I wonder how that would work with interior pieces...
