Thanks to all on the forum. Thanks to all that post builds, I can appreciate the time and effort it takes. Had an XJ years ago with alot of bolt on stuff including serious offroad long arm 4.5 lift etc. When kids started happening I sold it. Didnt want to, but I told myself that one day I would build something more serious. Couple years ago the wife needed a good winter beater got an XJ and fixed it up for her....started to get the fever again :shhh:
Fast forward to now a $600 rust bucket but good mileage and the dang ac works! Anyway, I am a noob.. just a guy having fun in a garage...Im open to criticism but just know im a noob with both limited knowledge and limited budget. "Unfortunately" it is just a basic coil spring, shock and rear leaf setup. Nothing too fancy that you haven't seen before. Alot of this steel I accumulated over the years and literally pulled from my yard.
Just wanted to preface a bit. I am more than open to advice or suggestion...I really appreciate it and am willing to learn.....but brace yourself for plenty of noob questions. Now the fun!
Basic goals for this general purpose machine include:
"Low cog" on tons, mini boatside, 40" tires. Whatever stretch I can get away with. "budget" hydro assist setup.
DIY 3 link front, DIY removable crossmember, hi steer
Rear is leafs, rear shock towers
5.38 gears front rear lockers
SYE and clocked tcase
This is what im going with. 99-04 F250 Axles. HP Dana 60 and Sterling 10.5 rear.
Ruff stuff steering, track bar and 3 link. 3/8 mounts all beef.
Ive been working on it already and here is where im at.
Frame plated all the way inside and out with 5/16. The front cradle is 1/8.
Goes all the way out and ties to bumper
Got all the rocker cut out and welded in the 2x6 1/4. I went up into the door but I wanted to keep the oem door seals.
Mini boat side with 3/8 plate that wont hit the floor pans.
Fixed the rusted wheel well and integrated 1/8 plate into rockers.
Front
Rear (the inside of the fender is rough, but ill skin it when I tub the rear.
Front bumper with beef 3/8 steering plate
Got the artec swap truss put on.
Here is the crossmember I made, doesnt have mounts yet. I did already clock the tcase and installed sye.
Id call that a pretty flat belly
Next steps are to get the axle under the front and figure out where its gonna fit. Get the leaf springs in the rear so I can figure out shock towers. In the front Id like to get as much stretch as I can with factory steering plate holes. I read somewhere that a 2wd astro box will do it. Hope you guys are into it, id be greatful for help with my noob questions haha. Ill post more pics asap.:thumbup:
Front
