Build 1 ton XJ on 39's
440swepty
Savannah, GA
Built 1 ton XJ on 39's
This Jeep has been my baby for the last couple years. I built it from the ground up. Body is a '95, drive train and interior from a rolled '99 w/ 50,000mi. Jeep has been built right and drives good w/ cold A/C. No expense spared. One ton axles are freshly built and have 1 trail ride at Uwharrie, NC. The current mileage on Odometer is 59,000mi. The only thing needed is hydo assit steering.
Will not part out! Don't ask!
Body:
- '95 2 door
- painted in 2008, Solid w/ no damage
- cut front fenders, cut and fold rear fenders, cut and fold rear quarters,
t&t frame stiffeners, TJ flares
- '99 wiring harness and fuse boxes
- '99 plastic gas tank w/ new fuel pump and custom 3/16 skid
- '99 booster w/ New Durango master cyl.
- Rigid Co. winch bumper with M8000 warn winch
- Custom 2"X6" rear bumper w/ wrap around corners, reese receiver
- Square tube rocker guards, I believe Kevin's offroad welded to frame stiffeners
- Steering box frame plate (like C-rok)
- Reinforced rear spring shackle mounts
- Clear title
Interior:
- '99 dash, carpet, console and vinyl seats.
- '95 door panels, and side paneling
- New heater core and evaporator
- Mopar cd player w/ new pioneer speakers
Engine/ trans.
- '99 4.0 liter, 59,000mi, completely resealed w/ head gasket
- New water pump, belt, ignition, t-stat, engine mounts, new hoses
- New 3 core copper radiator
- '99 AW4 59,000mi
- '99 231 w/ 2 low conversion, and Porc SYE
- Tom Woods CV drive shafts front and rear
- 2.5" exhaust, turbo muffler
Front Suspension
- Custom 3 link
- Lowers are 2" X .250 wall DOM, w/ all 4 adjustable ballistic fab joints
- Upper is 1.5" X .250 wall DOM, w/ fixed ballistic joint, and 3/4 hiem
- RE springs, Sky Jacker Nitro shocks
- Custom bar and brackets, 1.5" X .250 wall track bar w/ 7/8 hiems
- Custom trans. cross member with 3 link brackets, 6 bottom bolts,
cross bolted through frame, bolted to floor pan on top mount
- Adjustable bump stops
Rear suspension
- Rusty's 6 in springs w/poly bushings
- Customer rear shackle mounts
- Outboard Sky Jacker Nitro shocks
- Custom 1.5" X .250 wall traction bar with johny joint and shackle at
body mount
- Custom bump stops
Front Axle
- '79 Ford HP60, w/ 5.38 gears, full Detroit locker, stock 35 spline inner,
35 spine outer w/ Warn premium hubs
- New pads, rotors, bearings and seals
- Reid racing knuckles
- Ballistic hi-steer arms, ARP bolts
- T&T truss, coil mounts, and lower link brackets
- Custom upper and track bar brackets
- Solid diff. cover
- Steering is 1 ton Chevy inverted T w/ 1.5 X .250 DOM, factory box
Rear Axle
- 14 bolt Chevy, w/ 5.38 gears, Detroit locker, factory 1.5" shafts
- Disc conversion, New pads, calipers, and braided lines
- T&T U-bolt eliminator spring perches, ruff stuff traction bar mount
- Solid diff. cover, bottom shaved up to bottom bolt
Tires
- 39"x13.50r17 Irok Bias, w/ Hummer H2 aluminum rims
- Tires are 3/4 tread and have some rash
This Jeep performs well and has very few miles since being built. I will regret selling it but my second child is due in a few months. I have decided to make some changes in my life to better my family. I'm currently not looking to part out or trade. Please don't ask at this time. I will post some pics and can email more upon request. Would consider meeting or delivering. 912-655-7849 Kevin
Asking $10,500 for Jeep or $12,000 w/ 18ft trailer
DUDE!!!! HOLY HECK MAN!!!!!! i want this bad. but i already have a built 2 door lol
good luck with the sale brother.
Hmmm, trade for an extended cab ranger... I gots one of those! Haha.
You can see it on my website, its fully built too.
Bump for an awesome deal!
