Bruno™
- Edmonds, WA
not the same rig? :wierd:
Oops, didn't click your link. Haha.
:badpc:
-Lyle
No diesel. I love diesel's but I am not putting one in a buggy for two main reasons. They tend to be loud and they smell. There are a list of other draw backs for this type of rig but these are the two primary reasons in my book.
No turnkey. I "could" consider a built rig to start with to disasemble just of the drivetrain and axles IF the engine/tranny axles etc were all coming out of the same type of rig, but that is pretty unlikely. I enjoy the process of designing/building just as much as actually wheeling it
After doing a LOT of research on engines I have discovered several things.
1. There are a LOT of different engine choices aperwork
2. There are a LOT of issues mating each of them with a decent tranny
3. There are V8's that weight less than 4cylinders and 4 cylinders that put out more power than V8's.
4. The easy way out is to just stick a LSx in it. (That was the orginal intention after all) but would really prefer to find a better candidate (smaller, lighter, but still plenty of power).
5. I had never even considered the fact that I might find a decent engine/tranny and not be able to hook up an Atlas or Stak. I ran into this also!
6. I believe I want either a Turbo 4cylinder or Aluminum block V6. Preferably modern and easy to source.
My head is still buried in the books :looney:
Michael
What about a 4.0 stroker with an aluminum head? Not sure if it will mate up but a advanced adapters makes a low range box that integrates into a 42rle tranny so you get an additional 2.72 low range with no change in tranny length. That with an Atlas 4spd and you could get crazy low
Good idea Joe. I should build a buggy around a heavy, tall, low powered engine and then spend a boat load of extra money on it to get some small amount of power back and reduce some small amount of weight
Don't get me wrong I do really like the 4.0. It is an excellent engine but not the kind of engine that I want to build a buggy around.
At the moment the LSx engine really seems like the best compromise for power/weight/size/cost. There are a number of light weight (aluminum) V6s that would also be great engines but they are more difficult to come by and tend to be more money. I really like the idea of finding a lower weight, smaller engine but for the small penalty in weight it doesn't seem like a good choice at the moment.
On a similar subject, IF I do go with the 9's and the LSx there is no way I am going to keep it under 2K lbs. 2.5K might be possible still which is still reasonable.
Do I need more reduction than say 200:1?
Michael
How much does a typical "stater tube chassis" weigh? and whats with all this power talk, has your 4.0 ever seen above 3k rpm?
For weight reference I am usuing similar sized buggies with similar equipment. IF I went with a light weight turbo 4 cylinder and toy axles I could probably keep it under 2000lbs dry. With the few extra hundred pounds of 9" and 609 and a light weight V8 it would likely be closer to 2500lbs dry. I am not "worried" about weight, but I do understand that less weight does have significant advantages. The axle weight being un-sprung is less important than the engine weight. Tube buggy frame is about 300 lbs totally depending on size, tube, how finished it is.
I have never had any issues with the power from my 4.0. I don't NEED more power, on the other hand, I have never had a situation in ANY vehicle where I wouldn't mind a little more power (even if I dont get above 3K rpm)
The difference in weight from a reasonably light 4 cylinder and a LSx V8 is about 100lbs. That isn't that much of a weight difference on it's own. But would likely cost another 100lbs for fuel, cooling, tranny, etc.
Michael
What about 9" rear 44 front?
With this in mind, there are tons of toy's already built for cheap. The issues I see are the power of the more traditional 22re's and the more common stick tranny's.
Michael
How about a Tacoma or later model 4runner with a SAS (Solid Axle Swap) At least those had the V6. If I recall, those have a lot of probs with head gaskets and waterpumps failing.
I still like rear steer!
Also, didn't you have a Unimog or something you were going to use for this??
So what started as a Range Rover trail limo on 49's and a blown 572 has devolved into a run of the mill Reiter Yota buggy? Say it ain't so! You went to Embry-Riddle for christ's sake, at least do something different and cool like a sideways mounted rear engine Honda buggy, or something.
-----Matt-----
In a few months, no one will know what Reiter is...So what started as a Range Rover trail limo on 49's and a blown 572 has devolved into a run of the mill Reiter Yota buggy? Say it ain't so! You went to Embry-Riddle for christ's sake, at least do something different and cool like a sideways mounted rear engine Honda buggy, or something.
-----Matt-----
You went to Embry Riddle? Me too. You want fries with that?
You went to Embry Riddle? Me too. Prescott or Daytona?
Fries, and a lower rate on my student loan. Bitch :wave1::anon:
eace:
Prescit
Michael
