The H802CP piston has a 1.592" compression height which is 0.007" more than that of the 677CP (1.585"), and will therefore yield a 0.007" lower deck clearance and quench height. The resulting SCR would be 0.3:1 higher 'cause of the smaller dish volume and lower deck clearance. Both of these pistons are used with 4.2 rods.
The Keith Black IC944 pistons (21.6cc dish) have a compression height of 1.353" and must be used with the longer 4.0 rods. The advantage of using this piston/rod combination is that you can shave 0.020" from the block deck and still have an acceptable SCR (~9.6:1) but with a lower quench (0.051" with a 0.043" head gasket).
