ram360cid
- Westminster, MD
Well, I decided to install a 2" BB (Rocky Road) on my 1998 XJ. The kit came with spacers for the front, and 1-1/2" shackles and 1/2" blocks for the rear. I started with the rear:
Yesterday....
First, I jacked the left rear up, and took the tire off. Where is this shackle? Remember, I am still new to all this. Finally find the shackle, put the tire back. I start with the top bolt. I look at it, and figure it must have a weld nut on the other side, since there is no access to the other side. Try to loosen it with a wrench. Ain't moving. So I get out the breaker bar and try that (I did spray all the bolts with that stuff you are supposed to spray them with). I try to loosen it and I hear these loud pops as I try to loosen it. I am wondering if the weld nut is loose. Anyway, I persist and all I can say it that was a beeyotch! Then, I try the bottom bolt, and realize I don't have a 21mm deep socket. Run to lowes, home depot and then Sears (they have it). Get home and take the bolt out. Now I have the shackle out. Proceed to put the new shackle in. That was a beyotch also to get in, and to get the springs lined up also. So, I have the shackle in.
The kit came with shock extensions, so I proceed to remove the rear shock. The bottom comes off fine, then I try the top. SNAP, head breaks off first bolt. I am thinking sh*t, this sucks. Don't think about a solution, I move on to the next bolt. SNAP, that one breaks too. ARGH! WTF? I just want to hit something.
I figure I can either drill those out, or rotate the mounting location about 45 degrees . So, I will have to drill and tap new holes.
Today....
Well, decided to drill them out this morning. Went well, drilled both of them out. Need to go to the hardware store to get some bolts and correct size tap.
So, I figured I would give the other shock a try before I left. Ha Ha, knew it was going to happen. Snapped both of those also. Man, I guess this lift is going to try to beat me down. I didn't hear no bell....one more round....
A few hours later....
Well, progress has been made.
Drilled and tapped all four rear upper shock mounts, and installed the BPEs that came with the kit. I also swapped the other shackle. No issues there.
I will tell you it is not fun to press the bar pins out of 8 year old shocks.
So, the shackles are completed as are the BPEs for the rear shocks. Have to do the rear 1/2" blocks and also the front coil spacers. I think I will save the rest for another day, my right arm and shoulder is really sore from fahking with those upper shock mounts.
So, not much more left to do. I will definitely post pics when I am complete.
Yesterday....
Today....
