So it sounds like it's a 70mm M10x1.50 bolt?Yeah, that bolt is a goofy metric.
1.50 mm thread pitch
Shank is 9.92 mm or 25/64" - but a standard 3/8" should work.
The lenght is 2 3/4" base of bolt head to the end.
So, a 2 3/4" x 3/8" (head will likely be 9/16" or 5/8") standard coarse thread (pipe) and matching nut should get it done. Get a pinching lock nut or nylock nut to keep things snug.
:thumbup:
Your new track bar does not come with one?
Thanks for the offer ChiXJeff, but all i need is the nut and bolt
Uh, that's what I'm offering......
About 30 miles south of Mini-no-place, Minnesota.oh i thought you were offering the stock track bar... :confused1 didnt read it correctly.
where are you located?
Also, does anyone know that the hell the little yellow plastic retainer is called? The one that connects the lower tranny hose to the radiator.
so anyone know what size bolt/thread count i should use to replace my broken lower track bar bolt. (Jeep doesnt carry the OEM version anymore)
First post, WOO-HOO!!! Welcome aboard!Patriot4x4,i have the bolt & flag nut your looking for as spares laying around, work alot call me at xxx-xxx-xxxx Dan, Englewood
