LOUD02Special
- North Providence, RI
So I was trying to remove the two brackets that hold the U-Joint to the rear diff so I could lube the spline into the transfer case, and the first two bolts I tried snapped at the head. I didn't touch the other two on the other side bcause of this happening. Whatever these bolts were, I can't drill them out with what I have. Question is, with that one bracket off, is it safe to drive? I'm not at home, at the parents using their garage, so if I can limp it home 10 miles, I can use my car until I get to it. Thanks a ton for any help.
