mhead
- Encinitas, CA
Hi All,
I've a 1992 XJ 4.0. This vehicle had a D35 rear axle and a anti-lok brake system. Replaced rear axle with D44 and removed the anti-lok system. So now I have a standare Jeep hydraulic system: 1992 master cylinder plumbed to a proportioning valve (from a junk yard standard system - not the valve used with the ABS) and then plumbed to the wheels.
The system has worked well for several years.
About a year ago I noticed that the pedal OCCASIONALLY seemed to be fading under constant slight foot pressure. Ok...replaced the master cylinder. But the problem continued. Just sometimes I'd notice pedal fade.
Recently the pedal faded to the point where the brake light came on. And just a couple days ago I was in stop/go traffic and noticed the front brakes dragging.
Things I know:
Brakes properly blead
master cylinder never ran out of fluid
No leakage of brake fluid at any point in the system
MC reserviors maintain their fluid level for months and months
Both front brakes dragged.
Fading problem observed in two master cylinders
I don't think the rear brakes dragged but I'm not sure
This is so wierd that maybe I've got two problems.
Can anyone think of any way that the pedal can seem to fade EXCEPT air in the brake lines, fluid leakage, or a bad MC?
How can pedal fade cause the brake idiot light to come on? Is there only the switch on the proportioning valve or is there a limit switch on the pedal somwhere?
Anyone know of sketches showing cut-away views of the master cylinder and/or proportioning valve?
I'm looking for unusual suggestions..
Is there a 1-way valve somewhere that could limit the return flow and cause the front brakes to drag?
Thanks!
Mike
Things I know:
Thanks!
Mike
