- sacramento
im a little confused now, so i can figure this out, if i only shimmed the rear 3 degrees id be at say 8 degrees at the pinion and the same 5 deg at the tcase shaft. thatd be bad to have the pinion point up 8 degree and the tcase shaft point down 5. so hypothetically if i pulled the drop kit and say the t case is at like zero degrees, id want the pinion pointing down 3 degrees? so if the t case is at like 10 degrees pointing up, id want the pinion at like say 7-8 degrees pointing up, which would be like replacing the 6 degree shims with 3 degree shims?
