Broken axles suck!
The U-joints on stock axles are the first to go:
the U-joint moves and the weak C-Clip pops out, then the cap flys off and there is too much play and the ears are too weak to hold together. Full circle clips help, also tack welding the caps in can help too.
As Bryan C. was posting about, if you drive on a broken front axle the inner axle shaft can slid out and catch the stub, then it will ride up on the outer and push the knuckel apart. Good buy ball joints then the only part holding the wheel on is your stearing and a break line. At highway speed this could be really ugly.
I would never do that . . . again:
Tank Traps at 5pm on a sunday was not the best idea I had that weekend:
Got home at 4 am . . . .
