DoctorPhate
- Ottawa Canada
Ill try it when i get home from work at midnight... now i have to leave to catch the bus..
do you have a can of Coke/cola around?
...works wonders on corroded battery terminals, especially if the corrosion is keeping you from removing the cables. when you have them off, do as everyone has suggested, scrape them down with whatever you have.
remember, necessity is the mother of invention
good luck :thumbup:
First things first--fully charge the battery or you are wasting your time.
Clean all your cable ends and grounds.
After the battery is fully charged, start the vehicle and see if the voltage goes from 12v static to 14v running.
Now drive to the parts store and have them load test the battery and check the alternator output.
If the battery passes the load test, and the alternator's output is good, you either fixed the problem by cleaning the cables OR you have an excessive current draw when the switch is off and need to locate the draw and eliminate it or you will be back in the same position again.
