5-90
- Hammerspace
You are 100% correct but do you really have no problems with this? Just the thought of this sets off a ton of red flags for me.
Oh, I have plenty of problems with this!
If you don't trust the places where we go to get (biannual/annual/biennial, depending on location) smog checks, then take it up with them and allow me to go about freely.
It's bad enough I have to pay more for the smog check than I do for the tags as it is! Cutting off the 30-year rolling exemption was a Bad Thing as well (in a few more years, I wouldn't even have to have bothered with my 88 if they hadn't done that.)
And, considering CARB maintains records of all of the smog check results and can look them up by license plate or VIN, they're still "profiling" by whatever criteria and sending most of us with light trucks over 15 years old off to "Test Only" stations - just because.
NEWS FLASH - As far as I'm concerned, every station is "Test Only." I barely trust them to properly identify the #1 spark plug lead to attach the timer, I have to remind them that my 88 is "pre-OBD" and the CEL/MIL isn't supposed to be functional - every damned time! (I take the FSM in with me. If that's not an authoritative enough source, I go elsewhere.)
And, I've talked directly with CARB (the second time on the run I got sent to "Test Only") and that's how I found they could pull up the results for an individual vehicle (they'd asked me for the VIN or tag # - I gave them the tag, since I had it handy.)
And, despite the fact that my 88 put out less emissions than a comparable vehicle fifteen years newer - and than most vehicles in general ten years newer - I couldn't get the profile lifted. (There should be some benefit to aggressive maintenance, y'know...)
Couple that with the fact that, the more I see of "creature features" thrown on vehicles that I neither want nor need (ABS, DRL, ESP, speed-proportional steering, nav systems, ...) and therefore shouldn't be forced to pay for, is it any wonder I just want to say "Hang it all!" and buy something like a 1955 Willys to restore? Or an original DJ-5, just for the novelty value (convert it to 4WD, throw in a Lightning Rod shift kit and a twin-stick D300, and leave the keys in it. All those handles sticking up through the centre console should screw with just about anybody - providing effective security. If you don't know how to drive it, how can you steal it without a tow truck?)
[/RANT]
