Big Red
- Roscoe, IL 61073
XJPhoenix said:It sounds like pretty good odds to me.
If it has the 8.25 rear end, then it doesn't have ABS. The AW4 is more common than the AX 15, and some folks think it'll last longer too. The HP D30 is the only front axle on the XJ until 2000 or 2001. 3.55 gears are on ALL automatics, unless you have a special order with 3.73, or a 4 cyl (2.5) standard, then it'll have 4.10's and you'll have to watch out for axle-hungry 4.0 guys like me.
The 29 spline 8.25 started in 1997, (or was it 1995? I'm really tired and can't remember the exact year...) and was the only spline count.
Best way to find what you're after is to look for a 1998-1999 automatic-equipped 4.0 litre XJ with the 8.25 rear-end. It'll have the options you want, or better.
You're right on about everything & the 29 spline 8.25 started late in 96' so 97'+ 8.25s had then, and some 96' XJs if they were built very late in the year at the end of the run before the updated 97'-01' XJs started up.
96'+ had the nice Spicer 297 dana 44 sized u-joints in the HP30 up front so that coupled with a 8.25 29 spline and you are well on your way to a stout drivetrain. You cannot go wrong with the 4.0L/AW4 auto/231, the AX15 manual isn't bad either and while the auto AW4 is more common in the XJ, you can get the AX15 from the YJs/TJs if you need to.
The 242 Select Trac is a great t-case for a daily driver, it doesn't have the aftermarket support like the 231 Command Trac, but you can still get a SYE for it and that's about all you should do to a 231 anyways....if you want 4:1 gears and a SYE then you should just pick up a 241 Rock Trac from a Wrangler Rubicon owner tearing their stock drivetrain apart and putting in a Atlas or Stak aftermarket t-case.
