Spearfisher XJ
- SoCal/Maritime Academy
Whats the best year/make of truck to pull a 60 FRONT end from?
Thanks fellas.
Thanks fellas.
try 89 ford 3/4 ton truck axlesthey work well!
also you could use a ford 9" which doesnt require as much trimming... they are both huge axles and you need to cut them down to size or you will have a ton of rub..
A D60 out of the same kind of truck would work best. So find a 73-87 1 ton GM truck with the D60. It will bolt right in.
:laugh2:That's funny! The best year to get is a 78-79 Ford 1 ton. If you are still running stock transfer case
