GAdawg
- Dunwoody, GA
I've heard Rocky Road's are pretty good and I like thier mounting setup. I am not really into having ones with a step design. Any opinions on other brands would be great. Thanks!
jeeper821 said:c4x4 has the best rocker gaurds out there!!!!!
Weasel said:The best if your really need heavy duty rockere proctection is to cut the old out and have box welded back in. I had this done and I feel it's alot stouter then the any other type plus you don't loos clearnace under the door. I have a piece of tube welded to the outside of the box to act as a pivot point and give it a cleaner look.
roke40 said:Do you have any pics of this done. I've already got Rocky Road's and they have held up well but I'd be interested to see your set up.
Fore Wheeler said:HELLO!
anyone read my post above?????? same thing.
Fore Wheeler said:I was going to 'ditto' this thread, however I can't say 'they're THE best' without seeing everything, however I had c4x4's and I beat the sh it out of them and was very happy with them, I had the tube ones and would buy them again if I were to buy some, but I now am replacing the rockers with rec tubing for about $40 and very little work.
Jes said:Personally, I would not cut out the rockers and replace them with box unless you're tieing them(welding) into something more than just the sheet metal.
Jes
