Wow.
http://madison.craigslist.org/cto/2410996802.html
Modified 88 Jeep Cherokee - $750 (Madison, East Side)
Date: 2011-05-30, 1:48PM CDT
Reply to:
[email protected] [Errors when replying to ads?]
Fix it up or part it out, lockers alone worth the price!
The Good:
- 4 wheel drive
- 2 door
- ~ 6 inch lift - 5.5" ZJ front springs, rear Tomken packs with Rubicon Express AAL, Rocky Road shackles, Rubicon Express track bar
- 33 x 12.50 General Grabber MTs (5 of them) on US Racing chrome steel wheels
- Chopped fenders to fit the tires
- Dana 30 front axle with Posi-lok manual disconnect, OX locker, upgraded to 297 u-joint shafts and 4.56 gears
- Dana 44 rear axle (from an XJ) with Detroit locker, welded truss, reinforced cover and 4.56 gears
- NP 231 transfer case rebuilt with Advanced Adapters slip yoke eliminator
- Custom rear CV driveshaft
- ARB snorkel with custom K&N cone filter
- Upgraded 3 core GDI radiator
- Rusty's 2.5" exhaust and a 2.5" cat converter
- Welded-on rocker panel rock sliders
- Front steering skidplate (needs to be re-installed)
- Rusty's t-case skidplate
- Gas tank skid (needs to be re-installed)
- Custom heavy duty front bumper with steering box reinforcement
- Custom heavy duty rear bumper (needs to be re-installed)
- Full set of Factory Service manuals plus Chilton and
- TONS of spare parts!....and they all must go with the Jeep
The Bad:
- The Jeep has not been run much in the last 5 years
- Engine will run, but seems that it needs contacts cleaned on the sensors, it was idling at 1500 rpms and when warmed up would die if running up to 4000 rpms, old fuel in the tank may be an issue.
- Oil pressure seems a bit low, but not sure if that is the sensor or the engine; Engine is not smoking.
- Battery needs to be replaced
- Brakes need work to keep up with the oversized tires. master cylinder was replaced with one from a Ford E-350 (have the stock one)
- Could use a paint job; was last painted with white rattle can Rustoleum, so easy to update
- Bumpers and the rocker skids are rusty could be cleaned up and painted
- Front control arms at a steep angle make for rough ride; front upper arms are just extended stock arms
- Recommend a trailer to pick it up.
