"Loaded" hand built complete 4.6 liter stroker Jeep 6 cylinder engine- approx. 30K miles.
Runs & pulls very strong from idle...will change the whole performance of your Jeep..from crawling to redline!
$3,000.00 complete
also availble seperately are bellhousing, Centerforce II clutch & flywheel, rebuilt '76 T-18 w/ A.A. adapter & mainshaft for Dana 300/ Atlas T-Case
9.6 to 1 compression
254 H.P. @ 4700 rpm
323 ft/lb @ 3250 rpm
1991 4.0 liter H.O. block, bored (+.030) and decked (-.030)
1976 “Heavyweight” 12 c.w. crankshaft, rods/mains ground (-.020) 3.895 stroke
1976 4.2 liter rods (5.875”) w/ A.R.P. rod bolts
Sealed Power H802CP (+.030) Hypereutectic Pistons w/ graphite coated skirts- hand polished piston surfaces
CompCams #68-231-4 camshaft
Mopar Performance Head Gasket (#P459242) .041 thickness
Accel 26lb./hr. injectors (#ACC-150826)
Turbo City adjustable map sensor
3 angle valve job w/ new int./ext. valves
New rocker arms & pivots
Crane Cams .030 rocker arm shims
Mopar Performance valve springs (#P3614542)
Mopar Performance valve retainers (#P4529216)
Mopar Performance valve locks (#P4529218)
Borla Stainless Steel Header
Thermo-Tec insulation (header/intake)
Hesco Jeep 4.0 liter conversion wiring harness
Hesco off road air filter conversion
Hesco adjustable fuel pressure regulator
Hesco high flow thermostat housing/180* thermostat
Mopar Performance computer
Accurate Power 62 mm throttle body
On Board Air compressor bracket & plumbing
1983 Jeep York model 210 (10.3 ci) air conditioning compressor
