Update:
OK, I wiggled the wiring harness pig tail (about 18" long pig tail QC) connection under the jeep that goes to the fuel pump and wiggled the connector on the fuel pump cover plate to the gas tank, which looks to be the OEM push on style rubber cap version (BUT?) The Jeep started right up 4 times last night, and 4 more times today (could not get it not to start again). Today I tried to pull the connector off the fuel pump externally to clean the male/female connectors, but no joy. I was able to rotate it about 130 degrees back and forth through the cover plate. Never got the 2 wire connector off the cover plate.
There is a third wire that looks to be attached to the top side of plate, and it "feels" like it is bolted to the seal plate, but it is above the 2 steel fuel lines, so I can not see it clearly. If that is right, the the second wire through the rubber boot cap is a signal wire to the level sensor, and not a ground to the fuel pump. Does this make any sense you guys that have had one completely off?
The Carter, with the Bosch fuel pump on the Advance web site link below seems to have bare wire connectors (no wire, or wires?) held on by nuts, that go onto threaded posts. There is no through the cover plate direct connection to the fuel pump in that style. Is that a retrofit set up, or does the OEM wiring go through the cover plate? If it does then why does the kit have new wires in it?
I am trying to decide what to order for a rainy day when it does crap out, so I guess I need order a cover plate, cover plate seal, and a Bosch pump kit, and a brass punch. Did I miss anything else I might need?
Oh, and to refresh memories, this an 87 Renix, Wagoneer, 4x4, XJ, 4.0 L.
Thanks!!!!!:wave:
Seems that Master is Airtex.
If this links works
http://shop.advanceautoparts.com/ProductList.aspx?parttype=52&ptset=A&searchfor=Fuel+Pump
I found a Carter online at Advance for 66.99, is Carter any good?
The Bosch there is cheaper than the Master brand? Surprise!
On closer look the Carter has two, one has a Bosch and the other has a Walbro pump in Carter kit. Weird.
