- Colorado Springs
what belly height seems to work for those of you running 39s?? wheel base will be around 109.
Mine varies depending on if I am wearing shoes or not.
my belly pan is about 23"
i am on 42's, about 107 wb.
Good point. The numbers I gave above were for the lowest part of mine (the middle) which is about 1-1/4" below the stock unirail.When you guys give belly heights, it would be good to know if you have a belly flat with the "frame" rails or if it dips down. My MJ project will be flat from bottom of rail to bottom of rail but I don't know where the height is going to end up just yet. I'm going to be comparing it to the numbers you all are throwing out though. It looks like the thing is going to end up taller than I really wanted it, but at this point I would just like to get it working at whatever height it ends up at!Jeff
DITO
sweet guys thank only complaint people ever had about truggy was the height and the lean... anti rock took care of the lean now bringing the body down 4 inches and going up 2" in tire. should be good!
v8 swap should drop it another inch too![]()
Not much over the portly 4.0
