Battery relocation question
ZPD
Modesto Ca.
I am going to relocate the battery in my car to the back. I have a 4 gauge wire from an old amp installation laying around. Do you see any problem using this to run from the battery + to the engine bay? If I can use it then it will just save me some extra $.
Thanks
You should also run a ground of the same size to the engine block, for the starte motor.
I think a #4 is adequate size, but I know if speaker wire insulation is up to the job of insulating all the amps this cable will carry at start-up.
