FELIX
Who Knows, Ask Who
- Camarillo, CA
I'm getting battery drain from something. Need some suggestions on what to check. The only acc I have connected to the battery is a Heavy duty wire harness for the headlight, that runs through relays in stalled 6+ years ago, no trouble. All acc are off . Doors shut good interior light off. Stereo is off, & does not have constant power. I just replaced my 6+ year old Optima a couple of weeks ago w/ an Oddesy 1200, because it started losing volts, but now the new Oddesy is doing the same, just not as bad. Truck had sat for a few months, but started right up until recently. Last night, I had to jump it, only had 6V. Drove it around charged up to 13.08V. Metered it this morning, & I was at 12.58V. I've cleaned terminals @ battery end. Alt is still charging battery. I'm going to look at Batt cable ground @ engine block & connection to starter. No other mods have been done from the time it was sitting & still starting , until just after memorial day when I installed the front Detroit (no electrical impact) Any other ideas :banghead: :dunno:
