banjo bolt size for dual piston calipers?
Beezil
Member #Nay
Indiana-Missouri
hey.
went to plumb up the front calipers last night.....
figured my smaller ford calipers would be the same hardware as the bigger ones....
7/16 is too big, so I figure I need a 3/8 banjo and bolt (here's the reason you don't by brakeline assemblies! just change the banjo fitting)
I have a pair of 3/8 banjo fittings in the shopping cart now, and a pair of 3/8 bolts....
I'm just double-checking ford didn't do something idiotic and go metric for these things....
i'm cool with 3/8's right?
thanks
Do you know the year or vehicle they came off of? That might help find the right part by type vehicle or year.
If not you can always go to Pepboys and search through the bins untill you find a banjo bolt that works.
On my Ford 8.8 rear disks, the only place that had a banjo bolt for the calipers was Ford. NAPA carried the calipers but not the bolts. Go figure:rolleyes:
AARON
