Note from DJ
B Latch Relay on a Renix
Automatic Shutdown Relay ASD (or B Latch on a Renix)] it can give problems with fuel delivery and spark.
The ballast resistor (eliminated in 94) is a white ceramic piece mounted to the driver's side fender well. It reduces the power from the fuel pump relay to make the pump run quieter. It can be a problem if it is burned out causing an open circuit. It can be bypassed without any issues other than possibly a noisy pump.
There are multiple paths of power to the fuel pump. When you turn the key to ON, power to the pump is 12 volts through the ASD (or B Latch on a Renix) relay bypassing the ballast resistor, and this lasts for about 3 seconds and then the PCM/ECU cuts the ground to the relay if it hasn't sensed a crank sensor signal. Next, when you turn the key to START, the fuel pump gets 12 volts from the starter relay, bypassing the ballast resistor. Third, when the engine is running, from idle to just short of WOT [Wide Open Throttle], the fuel pump gets power from the fuel pump relay, through the ballast resistor where the power is reduced to approx. 6 volts. And last, when the engine is at WOT, the fuel pump gets 12 volts from the oxygen heater relay, bypassing the ballast resistor.
Relay Locations:
If you stand next to the passenger-side front fender and look down you will see 3 or [4 if you have AC] plastic cube shaped devices lined up in a row, these are the relays discussed above.
There placement is in this order from front to firewall in the order below order.
Fender
02 – Fuel Pump – B+ – AC
Engine
In front of these relays is a larger metal relay with a lot of wires connected to it, this is the starter relay.
If I was trying to correct your problem as I understand it I would mark the fuel pump relay with some tape. Then remove it and plug it back in several times, this will clean up the contact points some. Now try and start the Jeep.
If starts and runes then you only had dirty contacts if not swap this relay with one of the other relays, preferable with the AC relay if you have one second choice would be the 02 relay and try starting the Jeep again.
I hope this info helps post back what happens.
