Ball joint socket sizes?
obviously, bigger than any wrench size you have, HAHAHA
But seriously I am guessing in the 3/4 to 7/8 range, probably metric, everthing else on the axle is, so probably 19mm to 21 mm
7/8ths for the top, and I think it was 34MM for the bottom. I just did the driver's side on 1 of my '88s' earlier this week. I actually managed to use hub socket (36MM) on the bottom nut!
Question: are these castle nut sizes consistent with 97-01 XJ’s?
Trying to find online which castle nuts I need to buy for the upper and lower ball joints that go behind the knuckles.
Thanks guys,
-Fletch
