fdsa487
- El Cajon, a.k.a. The Box
Anyone near East County have one I can borrow for the weekend? Im sure whatever you have will be better than the crap they rent at Autozone. Thanks!!!!!
Did you take the axle shafts out? If not, then how do you know that there is nothing wrong with the ujoints?fdsa487 said:Do y'all think its a good idea to replace the u-joints while im doing the ball joints on both sides? There is nothing wrong with the u-joints at this point.
Kejtar said:Did you take the axle shafts out? If not, then how do you know that there is nothing wrong with the ujoints?
cal said:Stock shafts or alloy?
If your on stock shafts, I'd get Spicer 760 joints and grind the shafts a bit to let you install full circle clips - you should be able to find a writeup here.
if your running aftermarket shafts, spring for some aftermarket ujoints.. either CTM, OX or longfield..
fdsa487 said:Where can I find a shop that sells Spicer 760 in or around El Cajon, Santee area?
fdsa487 said:What is the best u joint that I can get for my D30 without having to modify anything to fit the 760 Spicer joint?
xjohnnyc said:Huh?? I think you answered your own question. Stock shafts? Just stick with the 760.
Spicer 760 is the way to go and if you don't mind grinding about 10 minutes per ear of the shaft you can make it a full circle clip setup which makes it a LOT stronger solution overall.fdsa487 said:OK so stock shafts will accommodate a Spicer 760. Thank you.
GSequoia said:Okay, proceed with the 760x joints.
