I was finally able to get an adapter for my compression tester. #1 had 25 psi. 2,3,4 and 5 had 145-155PSI. #6 was almost as high, but somehow it seemed a bit erratic.
I pulled the head and I found the #1 intake valve to be very slightly bent. One can see the carbon deposits on one side of the valve seat. #6 is starting to develop the same. Tomorrow I'll be replacing those two valves. What could have caused this?? I see no marks of foreign objects in those cylinders, or of the valves hitting the pistons. Am I better off replacing all intake valves??
At least now I know what the problem is :yelclap:
Thank you all.
Thank you all.
