Axle’s
Jeevy
Hi, I’ve got a 86 Cherokee 2 door I’m going to be using Chevy 1/2 ton axles, I have these already. So I want to use leaf springs instead of the jeep suspension mainly because of all the death wobble. Anyways I’ll be putting in frame connectors and boxing in areas that need strengthening. So I’m thinking the Chevy leafs will to long so I was thinking about maybe like a CJ
Maybe a YJ leaf would work? If you can't find what you want, check out Alcan Spring. They can custom build any leaf spring you want
