JPWilson
- Lafayette, IN
Jeep Cherokee XJ Parts - Super Duty axle swap in progress.
4- 35x12.5x15 Falken Wildpeak MT01 and Battleborn 5x4.5 beadlocks. Everything less than a year old, very low off-road miles, some fender wear on outside lugs. Includes black lugnuts. $1600
1 - 33x10.5x15 BFG KM2 Mud Terrain on Cragar soft 8, never mounted, was spare, used to run all 33x10.5 KM2 tires. $200
Dana 30 HP front axle - 1997 - 4.56 gears, chromoly shafts, Spartan locker, Solid diff cover, new axle side upper control arm bushings in November 2019, Barnes4x4 gusset on upper control arm mount, Artec HD lower control arm mounts, greasable axle tube seals, Lube Locker diff cover gasket. Spare oem shafts and some u-joints included also. $750
Ford 8.8” rear axle -1998 - 4.56 gears, new Yukon Grizzly locker (last fall), Solid diff cover, disk brakes, Lube Locker diff cover gasket, have old u-bolts and leaf spring plates to go with if you want them as well as spare 8.8" u-joint flange and 1310-1330 adapter u-joint. $750
Cavfab XJ high clearance cross-over steering system $150
Jeep XJ adjustable upper/lower control arms, worked well, Rusty’s brand -$120
Jeep is kept in garage, nice parts to bolt into your XJ and go hit some trails.
Located in Lafayette, IN.
