axle shims
tomwest49
I just installed a 2" budget lift on my xj I'm getting a little vibration from the drive shaft. Will an axle shim fix the problem and if so what degree shim should I use?
This should be posted on a Tech Forum. You'll need to figure out what the difference is between the front and rear(of the rear shaft) driveline to yoke angles. I believe it usually takes about a 2 or 3 degree shim in your application.
OK where's the tech forum for NAXJA. Oh you mean I have to go outside of NAXJA to get answers about XJs.
