TA2Jeep
- 661 - $o*Cal
So, found out through the alignment shop that an axle tube on my '99 Dana 30 is bent. A 1.5 degree upper ball joint will fix the issue, but would it be better to just go that route or replace the whole thing?
If I decide to look at replacing the housing / entire axle, what years would fit? Does ABS come into consideration at all? For my '99 I know that we have the 2 choices on brake rotors to choose from - does that come into play at all with having to look for a very specific axle housing?
Thanks!
Thanks!
