gearwhine
- Denver, CO
ok, I've got two big things planned in my head, but not sure which to do first, and when 1 is done, the other won't be done for probably a year or so.
background: I have a dana 30, 297's, dana 44 rear, 4.56 gears. 33" AT's , np231 w/ AA SYE, tera low, ax-15.....ok that's enough
I don't plan on going bigger than 37's in quite some time....quite some time, but for now sticking with 33-35" range. I have fun with that size where I wheel, and I do not break often.
option 1: new front axle. Probably a HP44, but a 60 if I can find a HP one at a decent price.
option 2: (my choice so far) Klune-v (4:1) to an EB dana 20. (www.highimpact.net) I like this because I love the 4:1 I have now, but I need lower in a lot of spots...so I'll have all kinds of choices. I like to be challenged more...so I can throw it into 2wd low after it's twin sticked. Also, this won't require any DS mods since it's only 1" longer than a 231 with a SYE, and my rear DS is almost reaching it's limit...this will bring it back to normal. To me this will be almost bulletproof with smaller tires even with the klune V.
The worrying is if the axles (front mainly) will hold up to a klune V and 35's. The 44 doesn't have any larger u-joints than my 30...which is the only thing I've ever broken. I really think a 44 is a worthless upgrade unless you have warns and CTM's. I just keep changing my mind between the two on which I should do first, and I need some other thoughts. So give me some! Oh and thanks for listening to my useless banter..
_nicko_
