AX15 leak part 2
Kejtar
PostMaster General
OK... so I did the Jbweld between on that seam and that seems to have limited it somewhat, but I'm still getting some leakage..... Is it possible that the lower two bolts are leaking through under their heads??? I have checked with the torque wrench their tightness and they are up to spec.... I am considering loosening them just enough to silicone around the heads and tightening them again.... does that make sense?
Kejtar
If you are leaking at the seam on an AX tranny the seal between the two halves and the intermediate plate is shot and needs to be replaced or redone. I believe they use RVT on it. When I looked at my AX-5 just now those bolts do NOT go all the way through into the case. So that would be a waste IMHO.
