R.DesJardin
- Clarkston, WA
OK, I had a vision, maybe a nightmare. But here goes,what if you connect the wires coming from your trans gear selector switch which is part of the XJ neutral safety switch to the AW4 solenoids. Since the TCM has to know what gear the floor shifter is in then it should be possible to use those wires to shift the trans. overiding the TCM, and if wired through a switch it would allow you to get overdrive by killing power to the solenoids aka 4th gear.
I'm sure it would work but not sure of the wiring since I sold my XJ to my son.
I'm sure there is someone out there that can figure this out. Of course this would require shifting the floor shifter for each gear.
Any thoughts?????????????
