problematicxj
- Peoria, AZ
I've had a P0740 and a P0740 PENDING code/s for the past 6 months. Had the transmission (AW4) rebuilt 3 times, luckily 2 were under warranty, we had another shop check wiring and replace the transmission wiring harness. I myself have tested the TPS, replaced the TPS, tested the solenoids at the engine bay transmission connector, the solenoid connectors themselves, and the TCM. The TCM and ECU were rebuilt as trying to fix this issue. I also did a visual inspection from the engine bay transmission connector to where the wires enter the transmission.
The transmission performs awesome when trailing and at highway speeds. I do notice sometimes it doesn't always go into overdrive/lock-up but it does 95% of the time. Sometimes upon startup and shifting from 1st to 2nd, it will sputter and run like an o2 sensor is going bad(No other codes). I shift it into N and rev it slightly and back into drive and it's back to normal. I also did a fluid change while testing the solenoids and made sure it was Dex/Merc as I know these AW4's are picky with the fluid. I'm absolutely stumped and can only think of the torque converter being an issue? There is also a whine type noise when in D or R from the transmission. Related to the T/C? I need to fix it so I can pass emissions. Any advice would be awesome.
