Ok well I got the slave/master cylinder today. And the clutch pedal assembly. Unfortunately it is NOT a clutch assembly from a 97-01 Cherokee. It looks exactly the same as yours, Char-broil. So, I'm trying to talk to the ebay guy to see if he actually has the right one. If not, I may have to use this. I see where you cut the clutch part off. So did you then attach the clutch portion to the existing brake pedal assembly? From the pics it looks like you used the older style clutch assembly because it has the small brake pedal rather than to wide one. So what clutch/brake braket combo works? Also, since I do have the correct master cylinder, I wonder if I'll have to extend the pushrod like you did?
