lawsoncl
- North Idaho
On the Renix TPS, the square 4-position connector is the output for the trans computer. I think it's a grey wire on pin B. One pin should have close to 5 volts all the time, one is ground, and the other is the sensor wire. I think its a grey wire on pin B. Measure between the sensor wire and ground. You should see the meter move smoothly between around 4.6 and 0.4 volts as you open and close the throttle all the way (key on, engine off obviously). The high/low numbers are ballpark and you'll probably be at least a few tenths different. The important thing is that it swings smoothly with out any hiccups, especially in the middle.
